Captkingdom
#1 Posted : 11 years ago
Captkingdom
I have searched threads, and can't find an answer to this.
The washer fills but when it should agitate nothing happens. There is a faint hum in the control panel but no other discernable noise. The timer will continue to advance and then drain rinse and spin, but still no agitation.
Can anyone help me with this?
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
If it spins ok in the permanent press cycle, then the problem is the timer.
Eric
Sherm1082
#3 Posted : 11 years ago
Sherm1082
fairbank would know better than me. I am no expert. I would have said the motor coupling.
