tank253
#1 Posted : Saturday, July 7, 2012 4:41:58 PM(UTC)
tank253
I am having a problem with my Samsung RS253BASB fridge. The freezer is working properly but the fridge side is building up ICE on the evaporator. I've already replace the sensor (DA32-00006W) and also replace the PCB Main Board (DA41-00295C) but the diagnostic test is still giving me the PLC (Power Line Communication) error (number 14) in the manual.
Is there anything that I can check where the error is coming from? Should I replace the Temp Sensor (DA47-00095E)?
Need Advise. Thank you...
Smeg
#2 Posted : Saturday, February 22, 2014 9:01:07 PM(UTC)
Smeg
I am having the same issue. I've replaced the temperature sensor (thermistor with two yellow wires), the thermo-fuse, and the main control board. Help???
