rickparagon
#1 Posted : Saturday, February 22, 2014 3:54:16 PM(UTC)
rickparagon
Hi all;
My outer stainless door panel got damaged and i am looking for advise or a walk-thru on how to replace this item??
From pics of the part i have seen it looks like just 8 screws?
But i am wondering about the top mounted control pad and if that will have to be disturbed?
festeraddams
#2 Posted : Saturday, February 22, 2014 7:02:02 PM(UTC)
festeraddams
Most figidaire dishwashers have 2 phillips screws about 2/3 of the way down the inner door (the rest at the top are T20 Torx IIRC), remove them, ODP slides down and off, new on is reverse of removal. 2 minute repair.
rickparagon
#3 Posted : Sunday, February 23, 2014 7:06:18 AM(UTC)
rickparagon
Mine has torx screws for all of them. 6 screws on side..(3per) and another 6 across the top.
Not sure if the 6 side screws just attach the ODP and the top 6 are for the controls at the top of the door assembly and the latch??
Any one else??
festeraddams
#4 Posted : Sunday, February 23, 2014 10:57:01 AM(UTC)
festeraddams
Well, that is an extremly uncommon ODP, but you are basically going to need to remove all the screws from either side, there may be only 2 you leave in at the top, but you can remove all of them if you like and it may be easier than trying to figure out which 2 to leave. Have a buddy handy to help catch the panel when you remove the screws......
