My dryer will heat and dry clothes but the knob/timer does not move. I have to manually keep time and turn the dryer off.
Groups: Expert
If this problem occurs in both timed dry and auto dry cycles, then the timer is bad. If only in auto dry, could still be timer but may be a problem in the heater circuit. You will need a multimeter to take some measurements.
Eric
