I had E2 code on the double oven which meant to change the electronic control board part #8302319 which I bought on order #4048579. I installed the board and now the oven works totally but there is no audible on every key function. It gave me a beep when power was turned on but that was it. All functions including timer make no sound. I ordered the control panel part #8P3046696 on order #4033475 and tried that and again no audible. So, i ruled out the control panel. I talked to a customer service person and they were unable to help. I a was advised me to try this forum. Any suggestions?
Below is the operators manual try turning the tones on/off and adjusting the volume (pages 6 and 7). |
THIS FORUM IS DEAD!!!!!!! |
