2 Pages<12
fairbank56
#11 Posted : Saturday, February 15, 2014 10:57:38 AM(UTC)
fairbank56
Groups: Expert
Looks like you need a new igniter. These things are VERY fragile and you must be very careful when installing the new one.
GE WE4X739 Igniter Assembly - AppliancePartsPros.com
Eric
mscerbak
#12 Posted : Saturday, February 15, 2014 11:25:01 AM(UTC)
mscerbak
ok, thank you . I also noticed dryer doesn't run continously when i turn start dial. I have to hold it in the start postion for dryer to kepp running. Is that another problem or will that remedy when i replace ignitor? thx
fairbank56
#13 Posted : Saturday, February 15, 2014 12:29:02 PM(UTC)
fairbank56
Groups: Expert
This is a new problem? No, it's not related to a bad igniter but sounds like a bad motor switch which could also cause your no heat problem. Now I'm not sure on your feedback to my troubleshooting help so you may want to call a tech rather than waste money on parts you don't need. Trying to walk laypersons through electrical troubleshooting is usually an exercise in frustration.
Eric
mscerbak
#14 Posted : Saturday, February 15, 2014 3:56:52 PM(UTC)
mscerbak
since the drum was removed the belt break switch prevented the dryer from running continuously . I ordered the ignitor . Thank you for all your help and patience.
Dryer not producing heat (Dryer Repair)
by cao824 6/5/2017 8:37:33 AM(UTC)
by scm518 10/7/2016 4:32:36 AM(UTC)
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings (Dryer Repair)
by hifroggyjenn 1/12/2012 10:26:47 AM(UTC)
Frigidaire dryer not producing heat after replacing main components. (Dryer Repair)
by LooseBoltsRob 12/20/2011 8:11:28 AM(UTC)
by Jeff B 1/6/2008 2:16:16 PM(UTC)
2 Pages<12
