I have a whirlpool gas range model# gs445lems2. When I turn on bake or broil I can hear the ovens gas turn on but the range igniters spark and the oven never ignites. The wiring is correct because it did this to me for a day or two then worked Fine for a month and now its acting up again. Please help!!!
Got it fixed!! Insufficient ground to the spark board. I ran a ground wire from the boards mounting post to a screw closer to the bake igniter. I haven't Had an issue since. We will see.
