jat
#1 Posted : Sunday, May 3, 2009 5:27:25 PM(UTC)
jat
i have replaced the ingniter. ingniter still does not get hot. the broiler works fine, & the stove works fine also. how do i test the thermostat, or the gas valve?
#2 Posted : Monday, May 4, 2009 6:10:11 PM(UTC)
Locate the Bake part of the gas valve. Remove the wires from the two terminals on the gas valve and check for continuity between them.
If there is no continuity then the gas valve has to be replaced.
If there is nothing wrong then the problem is a bad relay board.
- The part number for the gas safety valve is AP4098213
- The part number for the relay board is AP4102787
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 3468XRW | AppliancePartsPros.com
