How do I access and replace the hinges for my GE wall oven? The top door of my double oven does not close completely and the hinge is rubbing.
I cannot find any info on the given model number. Are you sure it has the second "0" in it?
If the 0 is a typo search, the model number at AppliancePartsPros. Then click on the part's description or picture and there is info in the Q&A section. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I cannot find any info on the given model number. Are you sure it has the second "0" in it?
If the 0 is a typo search, the model number at AppliancePartsPros. Then click on the part's description or picture and there is info in the Q&A section. use: JT950SASS - that's what's on all the manuals. 30" double wall oven. Thank you.
Still nothing so below is parts for a JT950SA3SS.
Take a look at item 281 in section 02. |
