Dtopham
#1 Posted : Tuesday, February 4, 2014 10:34:22 AM(UTC)
Dtopham
Thinking that it may not be switching to the right valves on time? It starts to fill normally and then seems to just start filling like mad overflowing the dispensers and running down the outside of tub to floor. I think when it is doing it's "mad" thing it should be pouring at least half that water directly into the tub. Is there an diverter ro something that could be broken?
rockstomper
#2 Posted : Tuesday, August 5, 2014 2:59:57 PM(UTC)
rockstomper
I had the same problem with my Bravos XL aswell. Same overflowing problem. I replaced the water valve assembly, and the overflowing went away. Just a fix that may work for others, as it worked for me.
