Well O'knowledge,
Turned dishwasher on but it never started. Bottom is filled with water. Tired all the following to no avail:
Removed both the middle and rear screen areas on the bottom of the tub. No debris of note except a 1 inch piece of glass in the middle screen area.
Removed float to clear debris. Seemed to work as it clicked however, I don't have a meter handy so not sure if switch is actually "switching".
Removed kick plate. Solenoid appears to function as it clicks and moved when trying to put the dishwasher in the various wash modes.
Tried to move impeller by wedging a screwdriver in the motor blades and twisting. Couldn't move more than an 1/8 of an inch. Didn't want to apply too much torque and bust the thing. It was noted that prior to doing this e motor was hot to the touch.
What say yee oh mighty well O'knowledge?
Btw: a link to the shop manual for this bad boy would be appreciated!
Thanks in advance,
JP
