TKerscher
#1 Posted : Friday, June 19, 2009 5:43:30 PM(UTC)
TKerscher
I have a Kenmore Elite HE3 Gas Dryer model # 110.92822102 the heating flame will not ignite. The coil turns bright red. I was lighting and then immediately going out. Now it won't light at all (no flame) but the element turns red. Any idea on what could be wrong.
Incidently I tried disconnected the vent pipe to see if that was impacting it and had the same result. I cleaned all lint out of everything, pipes, took the vent components apart and cleaned everything out.
Very frustrating.
Maintenance AJAY
#2 Posted : Friday, January 31, 2014 1:39:14 PM(UTC)
Maintenance AJAY
Sounds like you need a new glow bar. The glow bar need to reach a certain temperature for the gas valve to open. Element probably weak on glow bar. Now if I could only get someone to answer my question.
