AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer won't shut off on any setting and clothing never get even warm
My dryer won't shut off on any setting, at first the clothing still got dry , but after a couple of weeks now the dryer doesn't even get warm .
Groups: Expert
Try resetting electrical panel breaker for dryer. Check to make sure you have 240vac at dryer receptacle. Unplug dryer, check connections at power cord connection block behind small panel on back of dryer. Make sure connections are clean and tight, no burning/melting of wiring or terminals. If all checks out ok and timer will not advance when set for timed dry cycle, you may have a faulty motor switch.
Eric
Dryer Repair
