Hi, I have a GE monogram ZBD5900 dishwasher. When I push the button for a normal wash or even a quick wash, it starts up like normal, I hear the water going in, then it stops, no lights flash on the control panel. When I open the door there is water in the bottom of dishwasher, and when I close the door and hit the cancel button it drains it out like it should. It seems like after the water goes into the unit that whatever is supposed to happen next doesn't happen. Any ideas of what to check? Thanks.
You can test the various output relays to troubleshoot.
4.2.3 Relay Triac Output Test 4.2.3.1 To access the Relay/Triac Output Test Mode, the following buttons must be pressed in sequence: Heated Dry, Fast Wash, Super Wash, Heated Dry and Clear with the door closed.
4.2.3.2 The processor will select the temperature calibration test as a default mode and illuminate a number of program/ option LED’s depending on the temperature at the ther- mistor. A total of seven relay/triac outputs of the power control board (PCB) can be accessed and individually tested by manually energizing/de-energizing the relay/triacs and the actual supply circuits to the outboard components of the dishwasher.
4.2.3.3 Press the appropriate button to energize the relay/ triac output you wish to test according to the following table:
Program/Options button to press...... to test Relay/Triac output
Fast Wash Detergent/Rinse Aid Dispenser.
Normal Wash Heating Element (Drying) 1 second on, 2 seconds off.
Super Wash Heating Element.
Heated DryDrain Pump.
Water Temperature Wash Pump.
Delay StartDetergent/Rinse Aid.
Clear Water fill valve.
