is there any test to see if control board is bad thanks Richard
Groups: Expert
You can determine if the control board is the problem by troubleshooting to eliminate other components in the dryer as the source of the problem. What is the problem with the dryer?
Eric
Groups: Expert
Ok, just read your other post. With P1 plugged into board, check for 120vac between pin 3 and 5 (black and blue wires). If you don't have it there but do have it between 5 and 2 (black and white), then your door switch is bad. If door switch is ok, check for 120vac between 3 and 4 (light blue and blue) after pressing start button. You say you hear a click when pressing start button, but if your not getting 120vac at 3 and 4 of P1, then board is bad.
Eric
