I am sure this is the original washer in a 1992 park model trailer. It's what I live in now so any help with this abused washer would be awesome. I have been carefully using it for 2 yrs. It is a small washer so people have over loaded it, has no out of balance signal anymore and just keeps going. Now, I just grabbed agitator and it will stop with little resistance. Most of the time when agitating it does have a click noise if I put too much in washer. 3 bath towels is pushing it. I can stop click noise if I push on upper ring and kinda adjust drum ( I guess that's what I'm doing). I assume agitator will eventually stop all together. If I can fix both agitator problems that would be great. On some cycles it has recently started spin and water drained at same time. Drains water very well, all spin cycles great. I realize it's old, but I need to try and stretch it's use for awhile longer.
