Dryer is missing all wiring harness. Someone robbed it for copper scrap!!' It's a Whirlpool built and can figure most of it out with the typical WP diagrams on hand plus some memory. But would prefer to have the diagram and wire colors for this particular model. Any help is appreciated.
Groups: Expert
Parts diagram says wiring diagram part number is 3406699. Here is 3406699 rev A. Don't know if there are later revisions. Eric
That is exactly the diagram I needed. Thanks Fairbanks
Originally Posted by: fairbank56 Parts diagram says wiring diagram part number is 3406699. Here is 3406699 rev A. Don't know if there are later revisions. Eric I do not see where the wire diagram part number is listed on the various parts listing illustrations. And once one has the number for it, how do you locate the PDF for such?
Should have said thanks Fairbank 56 :-)
...part number for the wiring diagrams follows the listing for literature. I should have looked closer to item (1) and (1am) duh !!! I then Googled that number and found the PDF. I guess an old dog can still learn a new trick after all. Thanks again
