Tebos
#1 Posted : Wednesday, February 17, 2010 2:56:28 PM(UTC)
Tebos
I have replaced the evaporator on the refrigerator side, part number (AP4171999 (DA96-00020Q) ASSY 1 @49.71)...it is soldered and im pretty happy with myself but I think I have over looked the dryer? in the servive manual it has these instructions...
Evaporator is located in the bottom of refrigerator.
1. Take off the ductwork in refrigerator.
2. Disconnect the wire connector.(Heater and
Thermistor)
3. Desolder the capillary tube and the suction line
from the evaporator.
4. Remove the evaporator.
5. With a file, score the capillary tube just upstream
of the soldered point. Break off the soldered
section to help prevent solder from plugging the
tube during soldering.
6. Place a new evaporator and braze the suction
and capillary tube to evaporator using silver
solder.
7. Install a replacement dryer.
8. Evacuate and recharge the system using
reasonable procedures.
whats the replacement dryer?...I think it is located above the compressor and it has a port just like the compressor...is that it?...and what is it filled with? Thanks for any info...this piece of crap is out of warranty and am trying to do it myself and thought I was going to get off easy with a new evap...anyway hope I get good news from you guys =\
ALSO step 8...what materials will i need to evac and recharge...a/c manifold gauge, refrigerant, ...and what else? thanks again
Marat
#2 Posted : Thursday, January 23, 2014 10:42:47 AM(UTC)
Marat
