dmd1
#1 Posted : Tuesday, January 7, 2014 2:50:52 PM(UTC)
dmd1
Hi...I have a Jenn Air downdraft gas slide-in range (model JGS9900BDS) that is about 6 or 7 years old. When turning the oven on to pre-heat, it won't heat up past 170 or 200 degrees. How can I determine which part is my problem? Thanks!
TigerDriver
#2 Posted : Tuesday, January 21, 2014 11:35:51 AM(UTC)
TigerDriver
Search this forum for "temperature sensor," then find one of the several posts here that give its resistance. Then measure your to see whether it's in range.
Guest (4)
