jenn9674
#1 Posted : Tuesday, January 21, 2014 8:02:45 AM(UTC)
jenn9674
Dryer was working fine but then it never shut off- ran for hours. The timer seemed to be stuck at wrinkle free. I opened it and it shut off. I tried to restart it and nothing... the timer is not even ticking/ counting down which it usually does befor pushing start ... nothing? any clues???:eek:
fairbank56
#2 Posted : Tuesday, January 21, 2014 8:47:21 AM(UTC)
fairbank56
Groups: Expert
Model number???
jenn9674
#3 Posted : Tuesday, January 21, 2014 9:01:17 AM(UTC)
jenn9674
Originally Posted by: fairbank56 Go to Quoted Post
Model number???
i dont have it with me sorry... will have to post it later.
jenn9674
#4 Posted : Tuesday, January 21, 2014 1:51:49 PM(UTC)
jenn9674
Res6745pqo
fairbank56
#5 Posted : Tuesday, January 21, 2014 2:28:48 PM(UTC)
fairbank56
Groups: Expert
If it won't start and if you place timer in timed dry and timer doesn't run then you have a bad timer, assuming you do have 240vac coming into dryer. Unplug dryer and check that you have 240vac at receptacle. Open small panel on rear at top to inspect the power cord connection block. Make sure connections are tight and clean, no burning or melting.
Whirlpool 3979617 Timer - AppliancePartsPros.com
Eric
