lucian
#1 Posted : Monday, January 20, 2014 12:11:16 PM(UTC)
lucian
maytag washer onlly spins and drains repaced water inlet valve, screens clean. water coming through hoses not machine. waterlevel switch tested good. local company wont take part back because i put on the washer. what next,help limited funds.:confused:
fairbank56
#2 Posted : Monday, January 20, 2014 5:29:14 PM(UTC)
fairbank56
Groups: Expert
Probably need a new lid switch assembly. This circuit is designed to blow the fuse in the fill circuit if the lid switch is failing. Lid switch assembly includes the lid switch, check switch and fuse.
Whirlpool 22001682 Switch, Lid Assembly - AppliancePartsPros.com
Eric
