My ice maker froze up. So I took it all apart defrosted it and got it working again. but now it only gives me crushed ice not cubed, what is the problem?
You have a solenoid switch It switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Part 34 is the solenoid in this diagram. http://www.appliancepartspros.com/sect/9/e/d/9ed-cjjjjf.gif
thank you. I will give it a try
to WOODCHUCKIE, Thanks for the advice, Worked like a charm
