Bsemina
#1 Posted : Saturday, January 18, 2014 9:34:34 AM(UTC)
Bsemina
Kenmore combo: washer does not work. It fills only when dryer is running. I understand that washer is connected to the dryer start circuit. How can I fix it?:(
fairbank56
#2 Posted : Saturday, January 18, 2014 11:42:33 AM(UTC)
fairbank56
Groups: Expert
Model number???
Bsemina
#3 Posted : Saturday, January 18, 2014 4:50:07 PM(UTC)
Bsemina
It a Kenmore combo model 417 94 702 300
fairbank56
#4 Posted : Sunday, January 19, 2014 5:23:10 AM(UTC)
fairbank56
Groups: Expert
You saying the washer won't do anything unless the dryer is running? Then it fills? Does it do anything else. Washer and dryer wiring is separate except for the common connection at power cord connection block. Washer is not connected to dryer start circuit. Did this work ok previously and now you have this problem or is this new to you?
Eric
Bsemina
#5 Posted : Sunday, January 19, 2014 6:45:27 PM(UTC)
Bsemina
This is the first time. Fills up only if dryer is running. Once it fills up, nothing more happens. Motor doesn't start.
If dryer is off, it doesn't fill up.
