3 Pages<123>
darkfalllover
#11 Posted : 14 years ago
darkfalllover
wrote:
i agree with you,i like this forum
fasucre
#12 Posted : 13 years ago
fasucre
Originally Posted by: Fenian Go to Quoted Post
How do I remove the door on a GE JE1590SC01 ? Does the door lift off from the hinges, both located on the left-hand side, by simply pulling straight-up and popping out ? Or, must outer cabinet be removed in order to acres the hinge assembly/mechanism ?
Where you able to remove the door? How?!
Thanks!
ParonMIlls90
#13 Posted : 12 years ago
ParonMIlls90
thanks I have the same problem with my door. this can help me
markedward
#14 Posted : 11 years ago
markedward
Never thought of fixing the outer door frame in this way. This is really helpful thanks for sharing it.
view all builders
MikeWolfes
#15 Posted : 11 years ago
MikeWolfes
good suggestion it is .. i was too looking for it
avswindows
#16 Posted : 11 years ago
avswindows
Thanks For it information
djpenn
#17 Posted : 10 years ago
djpenn
Originally Posted by: yiwen Go to Quoted Post
The outer door frame of my JVM1840WD001 was cracked and eventually broken on the bottom. I ordered the replacement part from appliancepartspros.com for JVM1840BD001 since I don't want to pay $200 for the whole door (GE does not make individual part for JVM1840WD001, so I settle with a different color: bisque instead of white). To replace the outer door frame, you would need to use putty knife (the one you use for dry walling) to remove the inside door frame by prying against the inside metal frame. Once you remove the inside door frame, you will see two screws that secure the door handle. Unscrew them to remove the door handle. Once the handle is out of the way, you will see (from outside) there are 2 more screws that secure the outer door frame to the door assembly. Unscrew them (be careful not to let the outer door frame drop because there is the glass attached to it) and use the putty knife to remove the outer door frame. From this point on, the removal and installation should be straightforward.
Do you have to remove the door first? If so, then how do you do that?I don't want to break the new frame before I get the old one out so don't want to pry and poke until I know for sure.
mayallen
#18 Posted : 9 years ago
mayallen
Thanks for sharing the information, I had a similar problem with the microwave oven I bought from best brand appliance Premium Home & Kitchen Appliances Store Vaughan, Toronto | Best Brand Appliance but I had some professionals come in and fix the door for me. I was a bit cautious of working it on my own because microwave ovens have very high voltages and can have very high currents while operating. The high voltage capacitor can retain the charge for a long time.
McGear10
#19 Posted : 8 years ago
McGear10
Nice info. :)
IJenkins
#20 Posted : 8 years ago
IJenkins
Can you post some pictures of your door frame?
3 Pages<123>
