jmrdmd
#1 Posted : Tuesday, January 14, 2014 11:07:58 AM(UTC)
jmrdmd
Hi All,
My Kenmore Elite French Door Refrigerator model # 795.75192401 occasionally locks into a continuous run mode when you open the door. If left this way it will freeze all the food in the upper area. It beeps and then the temperature read out looks like the attached picture. It will reset and run normally for a while if you unplug and plug back in. Other than this annoyance it works fine.
Thank you for your help.
Jan
jmrdmd attached the following image(s):
jmrdmd
#2 Posted : Thursday, January 16, 2014 4:40:14 AM(UTC)
jmrdmd
Any help please?
#3 Posted : Friday, January 17, 2014 3:04:42 AM(UTC)
Put your model # in the online Sears parts site and locate the main control board, probably a sticking relay on the board.
jmrdmd
#4 Posted : Monday, January 20, 2014 11:14:47 AM(UTC)
jmrdmd
Thanks so much for the help...I ordered the board from Sears. Is it behind the cover in the rear?
Thanks again
Jan
#5 Posted : Tuesday, January 21, 2014 12:28:48 AM(UTC)
I think this is an LG refrigerator. Control board probably behind the cover in the back.
jmrdmd
#6 Posted : Tuesday, January 21, 2014 3:16:28 AM(UTC)
jmrdmd
Thanks...board is coming today. I'll keep you posted.
Jan
