elymoe
#1 Posted : Sunday, January 12, 2014 8:44:11 AM(UTC)
elymoe
When the dryer is turned on the timer does not advance and there is no heat. Is the problem with the control timer or is it something else ?
fairbank56
#2 Posted : Sunday, January 12, 2014 9:47:35 AM(UTC)
fairbank56
Groups: Expert
Is that timer not advancing in auto-dry only or both auto and timed dry?
Eric
elymoe
#3 Posted : Sunday, January 12, 2014 9:51:59 AM(UTC)
elymoe
Eric
Both auto and timed.
fairbank56
#4 Posted : Sunday, January 12, 2014 12:33:54 PM(UTC)
fairbank56
Groups: Expert
Check for 240vac at the dryer receptacle. Should also have it at dryer power cord connection block. Check connections there for broken/burned wires. Dryer motor runs off of 120vac, timer and heater use 240vac. If good, unplug dryer, check continuity between power plug L-2 blade and timer OR terminal (L-1 goes to timer BK terminal). With timer on in timed dry you should have continuity between timer OR and TM as well as between BU and BK.
Eric
elymoe
#5 Posted : Thursday, January 16, 2014 1:14:49 PM(UTC)
elymoe
All checks out. Replaced the timer. Still no heat and the timer does not advance.
elymoe
#6 Posted : Thursday, January 16, 2014 1:20:41 PM(UTC)
elymoe
All checked out. Replaced the timer and still no heat and no advance on the timer.
fairbank56
#7 Posted : Thursday, January 16, 2014 1:44:20 PM(UTC)
fairbank56
Groups: Expert
Turn timer on to timed dry cycle. Do not press start button. Does timer advance without motor running? It should. If not, you have a wiring problem or your not getting 240vac to dryer.
Eric
Guest (5)
