2 Pages12>
fredini
#1 Posted : Wednesday, January 15, 2014 9:13:56 PM(UTC)
fredini
Hi-
I have a Roper washer that has worked great for the 8 years I've had this house but it just stopped working. The water fills and drains fine, and the lid switch is fine but the spindle will not turn and the spin cycle won't work.
I cannot find a model # on the machine but I can tell you its a top loading 24"wide machine. Tell me where to look for the model # and I'll look it up but it doesn't seem to be on the stickers on the back.
Any clues as to the problem? I'd love to fix it over replacing it if possible!
thanks in advance!
fred
fairbank56
#2 Posted : Thursday, January 16, 2014 6:41:38 AM(UTC)
fairbank56
Groups: Expert
Can you hear the motor running or humming at all? Look under lid for model number. Can't be of much help without it.
Eric
fredini
#3 Posted : Thursday, January 16, 2014 7:34:45 PM(UTC)
fredini
AHA! I found the model # under the lid- it is a Roper Model # RAB4232DW0
I do hear the motor humming, just no movement. The lid switch seems to work, and it fills and empties fine. From what I've seen on the forums here it sounds like I may need to replace either the coupling or the belts? Any advice?
fredini
#4 Posted : Monday, January 20, 2014 6:58:14 AM(UTC)
fredini
fairbank56
#5 Posted : Monday, January 20, 2014 8:01:30 AM(UTC)
fairbank56
Groups: Expert
Yes, sounds like the motor coupler may be bad. There are no belts.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
fredini
#6 Posted : Monday, January 20, 2014 8:58:06 AM(UTC)
fredini
Thanks! I have ordered the part!
fredini
#7 Posted : Tuesday, February 25, 2014 7:56:16 PM(UTC)
fredini
Hi- So the new coupler worked great and the installation video was very helpful. Only now, two weeks later it has started making a god awful noise on the spin cycle of metal rubbing- listen here:
https://drive.google.com/file/d/...C1ybkR3/edit?usp=sharing
Any advice?
fairbank56
#8 Posted : Wednesday, February 26, 2014 4:55:53 AM(UTC)
fairbank56
Groups: Expert
Post your video on youtube.
Eric
fredini
#9 Posted : Thursday, February 27, 2014 10:46:50 AM(UTC)
fredini
Its a sound file so it won't go on Youtube- hopefully this share is more accessible- you should be able to listen to it from a browser:
https://www.dropbox.com/s/866ghk...ng%20Machine%20Noise.m4a
fredini
#10 Posted : Thursday, March 6, 2014 9:30:57 PM(UTC)
fredini
Here is the Youtube video: Washing machine noise - YouTube
I called and the person on the phone suggested this could be a bearing but it doesn't sound like there to me. Advice?
Guest (4)
Roper won't spin (Washer Repair)
by kellyg 6/1/2009 1:34:48 PM(UTC)
by oznib 1/18/2008 10:05:06 PM(UTC)
2 Pages12>
