mrcruz804
#1 Posted : Tuesday, January 14, 2014 5:37:13 AM(UTC)
mrcruz804
When the washer drains, are both pumps used to facilitate the drainage or just the smaller drain pump by itself?
I'm having a non-draining issue but cant see to pinpoint the issue. The drain line goes to the disposal at the sink. the line looks clear and the disposal is clear. I removed the small drain pump and don't see any debris. and the flapper moves freely as it should. When I run the drain cycle, I can see and hear the smaller pump running but the water doesn't drain out. I was wondering if the larger pump also was supposed to run during drain cycle.
please help!
mrcruz804
#2 Posted : Wednesday, January 15, 2014 7:24:36 AM(UTC)
mrcruz804
FIXED! Visually, the return line looked clear. but upon closer inspection, it was actually clogged with clear grease build up that was preventing flow. A quick $12 later for a new line and she's working good as new.
LG Washer eats drain pumps (Washer Repair)
by Mdavid1955 9/20/2020 1:12:51 PM(UTC)
Bosch drain pumps does not turn off? (Dishwasher Repair)
by dallymemally 10/26/2007 2:29:15 PM(UTC)
