I have A Carrier 58MCA060 furnace with a vibration in the draft inducer motor. I replaced the blower wheel today & it seems a bit better but I can still hear it vibrating upstairs. The furnace is in the basement. There is no play in the inducer motor shaft. Is it normal for these things to vibrate? I notice the motor assy. is mounted on rubber cushions. Thanks for your help!
