AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Freezer not freezing and fridge not very cold even on highest setting
Freezer just cool and no longer freezing and now the fridge is barely cold even on highest cool setting...
What is on and what is not re: compressor, fans etc.?
You can usually hear the compressor but should also be able to feel it vibrating.
Does the compressor cycle or is it off or does it run continuously. |
THIS FORUM IS DEAD!!!!!!! |
Can hear the fan and it seems to blow a little cold air. Fridge much quieter than usual and not vibrating As usual.
Seems to have a continuous very faint hum.
You have to find out what is humming?
You cannot just guess at troubleshooting as your problem can have many different causes. |
Originally Posted by: denman  You have to find out what is humming?
You cannot just guess at troubleshooting as your problem can have many different causes. How do I do that?
Here are your parts Parts for Maytag MBB1952HEW Refrigerator - AppliancePartsPros.comOpen the freezer door. If it has a door switch activate the switch. Is the fan at the back of the freezer running? Pull the unit away from the wall. Remove the lower rear cover. Is the condenser/compressor running? Is the compressor running? You can usually hear it but also should be able to feel it vibrating and it should be warm. |
I have a whirlpool side by side and the compressor isn't coming on with same symptoms as marie4965 not sure what to replace?
