burtonjt36
#1 Posted : Saturday, January 11, 2014 7:15:03 PM(UTC)
burtonjt36
Model number: MDB7749SAB0
My dishwasher's drain pump will run at the end of the cycle even if the tub is dry. I looked underneath the unit and the drain hose still has water in it. I replaced the overfill float switch and electronic control. I still have the problem. The was wash cycle works normally. Any ideas?
Is it possible for something to be plugged where I cannot see it? What about a check valve being stuck?
This unit is only 1-1/2 years old and I do not want to replace it.
#2 Posted : Sunday, January 12, 2014 1:15:30 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
