My washer went through the wash cycle and filled up to rinse, but now it won't drain. If I turn it to the spin cycle...it spins...but the water is still in there. When I flip it back to rinse it makes noise, but the water doesn't drain. Please help me!! :(
Groups: Expert
We need a model number.
Eric
Groups: Expert
May be something in the drain pump or hoses preventing proper drain. You will need to manually drain the washer, remove the cabinet for better access to the pump and drain hoses.
Eric
