the motor in the timer of my dryer runs too hot and just got burn l replaced the timer motor and the same happend can somebudy help me?
Groups: Expert
What is the part number of the timer you are using? Did you replace the whole timer or just the timer motor? What is the writing on the side of the timer motor?
Eric
than you for answer. yes I just change the motor and the reading was 125 v from one wire to motor timer budy and from wire to wire 0
Groups: Expert
What is the writing on the side of the timer motor????
hi fairbank65. yes the other wire is 125v also
Groups: Expert
Can't help you if you don't answer the questions, good luck.
Eric
lm sorry lm trying to answer all you are asking me so l don't know what l didn't answer
Groups: Expert
