kysowns
#1 Posted : Wednesday, January 8, 2014 8:45:42 PM(UTC)
kysowns
When I press the "Bake" button and then set it to the desired temperature, it then goes to 100 degrees like usual. However, instead of the oven coming on, after a minute or so, the temperature just turns off. This has been a progressive problem, which started a few months ago and would only happen occasionally, but now happens every time I try to turn the oven on and I can't get the oven on at all. Does anyone know what is causing this problem? Thank you in advance for any help.
#2 Posted : Thursday, January 9, 2014 2:08:32 AM(UTC)
Parts for GE JMP29GT1BB Range - AppliancePartsPros.com
You could check the oven sensor.
See the below link and check out 7, 8, 20 and 21
http://www.applianceaid.com/ele...-range-repair-topics.php
If it is OK then odds are that the control board/timer is shot.
Unfortunately it looks like this part is obsolete.
