Hello. Having an issue with the dryer not heating during a cycle. It happens intermittently. For a few cycles it's fine, but then no heat. Seems to be happening more often of late. Dryer starts and runs fine. Already tested the thermal fuse, cycling thermostat, high limit thermostat, and the heating element. They all tested fine on a multi-meter. Not sure where to go from here. Maybe the heat selector switch? Thanks in advance. Scott
Any experts want to take a stab at it?
Groups: Expert
Could be the timer, motor switch or temp switch. You would have to troubleshoot using a multimeter to monitor voltages at certain points with dryer in operation waiting for the intermittent problem to occur to determine the defective part.
Eric
