Realized I didn't clip the wire#2 on the J1 plug after installing the new board. Now the fridge has cooled down nicely, but the freezer is too warm (soft ice cream). Compressor seems to be running non-stop. Does this need a recharge?
You may have caused a refrigerant leak when you defrosted the evaporator, just check.
Thanks, how do I check for a leak?
If you only have partial, light frost on the evaporator, you have a leak.
