The wires going to one of the burners on my stove were exposed because the plastic covering had been burned off. Some water got under the burner and shorted it out. Now none of the burners work but the oven still works. Can this be fixed and if so what part(s) do I need?
See the attachment for the tech sheet. It should be reparable. You will have to find the connection or wire that is common to all elements and is open. |
THIS FORUM IS DEAD!!!!!!! |
