Tigerpa
#1 Posted : Saturday, January 4, 2014 9:56:27 AM(UTC)
Tigerpa
I have a 30 " double wall oven. The top oven works fine. When I try to turn on the lower oven, I push the controls for temperature etc and it shows it preheating/broiling like it should. When I open the oven, neither the broiler element or the bake element is warming. The controls show it reaching the entered temp on the controls but the oven is still cold. What is my problem? Is it a thermostat or what? I really don't want to spend the money for a new oven unit.:(
#2 Posted : Sunday, January 5, 2014 3:05:45 AM(UTC)
Parts for Whirlpool GBS307PDQ9 Wall Oven - AppliancePartsPros.com
See the attachment for your tech sheet.
[COLOR="Blue"]The controls show it reaching the entered temp on the controls but the oven is still cold.[/COLOR]
I am not sure I understand the above but if you mean that the oven comes ready but has no heat then odds are that the control board is bad.
File Attachment(s):
GBS307P.pdf (169kb) downloaded 0 time(s).
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
lower oven won't heat (Oven Repair (including Ranges and Cooktops))
by crazyoldchick 11/14/2013 7:27:19 AM(UTC)
by rleescott 7/28/2013 8:07:59 AM(UTC)
