2 Pages12>
Jason LaPort
#1 Posted : Sunday, December 29, 2013 1:53:17 PM(UTC)
Jason LaPort
Not sure the exact age of the washer but it recently started making a grinding/clicking noise and it won't spin. Water drains fine. I'm thinking its the clutch but just wanna make sure that I'm not buying the wrong part for it. I know its gotta be at least 5 years old. Thank you for your time and have a happy new year all. :)
fairbank56
#2 Posted : Sunday, December 29, 2013 5:47:57 PM(UTC)
fairbank56
Groups: Expert
That's an 05 model. Bad clutch doesn't usually cause any grinding/clicking noise. Does it agitate ok? If not, probably a bad motor coupler. Can you post video to youtube so we can hear the noise? No spin can be caused by bad gearcase, slipping clutch, broken brake cam driver, bad drive block...
Eric
Jason LaPort
#3 Posted : Monday, December 30, 2013 6:39:14 AM(UTC)
Jason LaPort
Washer making noise - YouTube
Here's some video of the sound. It doesn't agitate or spin.
fairbank56
#4 Posted : Monday, December 30, 2013 6:59:58 AM(UTC)
fairbank56
Groups: Expert
Well, it's not the clutch as that has no function during agitation. Sounds like a broken motor coupler. Pull the motor to check the coupler.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
Jason LaPort
#5 Posted : Monday, December 30, 2013 9:31:29 AM(UTC)
Jason LaPort
Thanx man, I ordered the part and I'll give you an update when I get it installed to let you know how it works. Have a great new year. :)
Jason LaPort
#6 Posted : Tuesday, December 31, 2013 1:39:58 PM(UTC)
Jason LaPort
Well I was quite shocked at the speed of the delivery. Ordered the parts yesterday, early afternoon and it came in the mail today. After a few cuss words I had the whole shabang apart and the new pieces back on and followed the directions backwards to get everything put back on and now it wont spin or drain. Is there something I missed? It was a severe pain to get it all back together the hardest part was lining up the shroud and getting that back on. I'm hoping for maybe a loose plug or something simple like that. I'm gonna pull it back out and try to see if I can find the problem. Thank you for your help and have a happy new years. Jason
Jason LaPort
#7 Posted : Tuesday, December 31, 2013 2:30:27 PM(UTC)
Jason LaPort
I was looking for more info and several people mentioned that there washer was humming but not doing anything, mine isn't making any noise at all. Thinking that something isn't fully plugged back in.
fairbank56
#8 Posted : Tuesday, December 31, 2013 2:53:22 PM(UTC)
fairbank56
Groups: Expert
Check the motor receptacle, make sure a pin didn't get bent over. Also, if you removed the cabinet, did you remember to plug the lid switch back in? Motor won't work at all with open lid switch.
Eric
Jason LaPort
#9 Posted : Tuesday, December 31, 2013 3:02:19 PM(UTC)
Jason LaPort
Yup, I checked everything I could think of, there's only 2 plugs to unplug and plug back in so I double checked all that. The motor and pump went back nice n easy so I don't think I bent anything, Where is the motor receptacle and how do I check that? I double checked all the obvious plugs and everything seems to be in nice n tight. Not sure what else it could possibly be. The grinding noise was happening with the lid opened or closed so a faulty lid switch might be the issue too but I'm not sure.
Jason LaPort
#10 Posted : Tuesday, December 31, 2013 3:57:49 PM(UTC)
Jason LaPort
I unplugged the plugs again and everything looks good, no bent plugs, it just fills and nothing else.
roper washer wont spin (Washer Repair)
by nicvoi 3/31/2013 5:02:49 PM(UTC)
by nicvoi 3/31/2013 4:37:15 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
Roper washer wont spin and wont empty (Washer Repair)
by jgirl14572 10/10/2009 6:20:33 AM(UTC)
2 Pages12>
