Beezer4me
#1 Posted : Saturday, December 28, 2013 6:35:45 PM(UTC)
Beezer4me
Freezer not freezing and no fan blowing into freezer compartment; fridge side freezing; fan works fine next to compressor; no water being dispensed ; unplugged it for any hour plus and all restarted fine but after a few minutes, all went back to the quiet sound of motor humming along but no compressor cycling on and off for freezer; still no water dispensed. Assume filter is clogged after years of using same one; need help on temp issues; Thanks everyone !!
#2 Posted : Sunday, December 29, 2013 5:04:32 AM(UTC)
Remove the freezer back panel and check the frost pattern, if totally covered with heavy frost, you have a defrost problem.
