LTuttle
#1 Posted : Saturday, December 28, 2013 2:23:34 PM(UTC)
LTuttle
My washing maching turns on, fills up with water but will not agitate. It then drains but will not spin. We just installed the cam agitator repair kit but to no avail. Any suggestions?
fairbank56
#2 Posted : Saturday, December 28, 2013 3:01:42 PM(UTC)
fairbank56
Groups: Expert
If motor is running when washer should be agitating or spinning then you probably have a broken motor coupling.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
LTuttle
#3 Posted : Saturday, December 28, 2013 9:06:45 PM(UTC)
LTuttle
Thank you - I've just ordered the part.
fairbank56
#4 Posted : Sunday, December 29, 2013 4:56:12 AM(UTC)
fairbank56
Groups: Expert
Make sure to install the new coupler properly. Use a socket and hammer to tap the two plastic halves onto the motor and gearcase shafts. Tap them on until the plastic hub is flush with the shafts.
Eric
ErnieRay
#5 Posted : Monday, July 24, 2017 4:45:58 PM(UTC)
ErnieRay
You're being too fast to order parts. Go to YouTube and do a search on your problem. Knowledge is power.
