gregaguilar
#1 Posted : Saturday, December 28, 2013 5:39:45 AM(UTC)
gregaguilar
I hardly ever work on dishwashers but this one customer calls and says it is leaking at right hand corner of unit . I would assume it is a seal that went bad if so how would i go about replacing this bad boy thanks guys and gals
Lanbldr
#2 Posted : Saturday, December 28, 2013 8:09:38 AM(UTC)
Lanbldr
I have a Kenmore Elite that did the same thing, found wet floor under right rear corner. Inlet assembly seal leaking. $14 seal, installation involved rotating the inside grille of the inlet counter-clockwise about 1/4 turn. Unit needs to be out from under the counter to access the inlet assembly parts that are outside the tub.
gregaguilar
#3 Posted : Saturday, December 28, 2013 2:22:28 PM(UTC)
gregaguilar
thanks Lanbldr but the problem was the bottom door seal i replaced it it was a $13 part#154576501 i really appreciate your imput anyway
