How do you remove the water line from the pump to the ice maker. The Pump is in a three pump unit. I want to clean the line to the ice maker, because it is not making ice.
Originally Posted by: otmike01  How do you remove the water line from the pump to the ice maker. The Pump is in a three pump unit. I want to clean the line to the ice maker, because it is not making ice. Can you pull the line out of the connector and reconnect it by pushing it back in the connector or what:mad:
Joined: 3/10/2009(UTC) Views messages in topic : 1,363
Does your water dispenser work. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If you still need to disconnect the water line, if it's not a threaded fitting, you push the blue ring in and then you can pull the line out.
