The dryer was running fine when my wife put a load of towels in the dryer selected a program and pushed the start button. When she pushed the start button you here a beep but nothing turns on. All the indicator lights work everything else seems ok I cleaned out the lint and took of the bottom cover and checked the fuse and it checks out ok. Now we just bought this house a few months ago and the dryer came with the house so we are not real familiar with this dryer. Any help would be greatly appreciated Thanks.:confused:
Originally Posted by: hunterhutch The dryer was running fine when my wife put a load of towels in the dryer selected a program and pushed the start button. When she pushed the start button you here a beep but nothing turns on. All the indicator lights work everything else seems ok I cleaned out the lint and took of the bottom cover and checked the fuse and it checks out ok. Now we just bought this house a few months ago and the dryer came with the house so we are not real familiar with this dryer. Any help would be greatly appreciated Thanks.:confused: Ok I checked the thermal fuse and its ok and I replaced the thermistor with a new one and the dryer still does not work the door light comes on and off when open and closed. I need help not sure where to go next
Have you considered the switch? It sits inside the machine behind the start knob. I had the same symptoms as you, and after replacing the start switch, my dryer is now working. It was also a possibility that my Thermal Fuse was bad, but it was indeed the switch. Hope this helps you.
