ducatiduke
#1 Posted : Sunday, December 22, 2013 8:42:21 PM(UTC)
ducatiduke
Only the refrigerator side is not cooling- freezer is working. Here is some background. We found there was water dipping from the water filter so I pulled the water filter and wiped it out... 2 hours later the temperature in the refrigerator is not cooling - the alarm was going of alerting us it was 58 degrees. Any suggestions? I unplugged it for 2 minutes and plugged it back in, but nothing.
#2 Posted : Monday, December 23, 2013 1:20:07 AM(UTC)
Is the freezer fan running?
ducatiduke
#3 Posted : Tuesday, December 24, 2013 11:54:35 AM(UTC)
ducatiduke
seems odd, but it seems to be running normal. I am thinking some of the water that was leaking from the filter caused something to act up. Odd.
#4 Posted : Wednesday, December 25, 2013 12:30:53 AM(UTC)
If no air to the fridg section, check the air returns for an ice clog.
Guest (4)
