Water line leaking from supply connection to the filter. About 5 inches past the supply connection a small break exists. When you activate the water switch to fill a glass it sprays at the break in the line. Or when the ice maker fills its tray it sprays from the break. I need to replace that filter line. I need parts and instructions how to replace it.
Water line from inlet supply line connection to filter leaking. I need to know how to replace it and if a kit is available
