Mick McGuiness
#1 Posted : Saturday, May 2, 2009 10:20:23 AM(UTC)
Mick McGuiness
Water leakes from front left of refer, icemaker works, freezer works, refer works. Checked all fittings, all OK. Maybe 2-3 times a day about 2 shot glasses of water apears on the floor. Where do I apply the duct tape?
Thank you in advance
Mick McGuiness
applianceman
#2 Posted : Saturday, May 2, 2009 12:14:40 PM(UTC)
applianceman
The drain is stopped up. In the freezer look at the back bottom under the evaporator coils you don not need to remove the evaporator cover just the food on the bottom two shelves. You should see a hole covered with ice remove the ice then using a turkey baser or any squirt bottle force hot water down the hole to clear the drain. Once done mix water with baking soda and pure it down the drain to prevent this from happing again anytime soon. Refrigerator Leaking Repair Guide
Mick McGuiness
#3 Posted : Saturday, May 2, 2009 5:24:15 PM(UTC)
Mick McGuiness
Thanks for the info, I checked the freezer and the bottom has frozen watr standing there. I will operate in the drain tomorrow,
Thanks again for the quick response.
Mick
Sarasota
