wa9zug
#1 Posted : Saturday, May 2, 2009 3:25:25 PM(UTC)
wa9zug
IMy MWO stopped heating. I found the diode measured 20 ohms in both directions (shorted?). I replaced it with one from my parts place. It still doesn't heat. I measured 120 VAC across the primary on the HV transformer.
Any ideas?:confused:
applianceman
#2 Posted : Monday, May 4, 2009 5:54:48 PM(UTC)
applianceman
Well 20 ohms definitely isn’t right so the old diode is bad. All most every time I see a diode bad the magnetron tube is also bad. Microwave Repair Guide
