kthygesen
#1 Posted : Monday, December 16, 2013 6:42:57 PM(UTC)
kthygesen
New to forum. Sorry if I am posting issue that is already posted. I read thru most and searched, but none where like my issue.
My upper oven did not heat over 200 degrees no matter the setting when I first bought my house. It would take over 45 min just to get to preheat to 200 degrees. I had a tech come out and tell me it was the control board. I replaced the control board myself via APP site and tried the oven again. although, it now heats up to desired temp setting, Oven still takes 30+ minutes to heat. It will not maintain temperature once you place a meal in it. I have a thermometer in oven and temp drops 50 -75 degrees. Bottom oven works fine, so I swapped temp probes. Same issue. Bottom oven works, top has same symptoms.
Is it other samll board that I have not replaced yet?
Thx,
Kevin
#2 Posted : Tuesday, December 17, 2013 12:54:34 AM(UTC)
[COLOR="Red"]DUPLICATE[/COLOR]
Please see the following
http://forum.appliancepartspros...n-very-long-preheat.html
Kitchenaid Double Oven Upper Oven very long Preheat (Oven Repair (including Ranges and Cooktops))
by kthygesen 12/16/2013 6:45:37 PM(UTC)
