I took the back panel of my dryer off in order to clean out the lint buildup, and now I am having an extremely difficult time getting it put back on. I have been unable to get the holes lined up correctly-the dryer drum being heavy doesn't help matters any. Any pointers on how to fix the issue? Thanks!
The drum weight should not affect the back panel as it is not supported by the panel.
Check to see if the panel has tabs that have to be inserted into slots in the frame before the panel can be screwed on. |
THIS FORUM IS DEAD!!!!!!! |
